• Spyderco Fred Perrin Street Beat
    Hello all,
    As the title suggests this is my first fixed blade from Spyderco so I just wanted to share my thoughts. I've been eyeing the Street Beat for a while now and decided to pull the trigger despite being very tempted by the Southfork. The Street Beat won out for size reasons in the end, with the Southfork being harder for me to justify when I already have the 'larger' fixed blade category covered (I know, I know, there's always room for one more! ).
    Anyway, these are my thoughts on the Street Beat:
    Here are the stats from Spyderco:
    length overall: 7.188" (183mm)
    blade length: 3.5" (89mm)
    cutting edge: 3.25" (83mm)
    blade thickness: .156" (4mm)
    weight: 3.2oz (92g)
    handle material: Micarta
    blade steel: VG-10
    The first word that came to mind when I picked this knife up was 'comfort'. The design is fantastic and my hand instinctively melted into the handle. I love big choils on my folders so I always had an inkling that I was going to get on well with the Street Beat and its huge lower choil. The balance is spot on and with your thumb locked into the spine jimping this blade isn't going anywhere you don't want it to. The handle is nice and thick so you know you have it in your hand but it completely vanishes in your grip. You're left with lots of VG10 out the front, although just how much blade there is is quite deceptive with your thumb riding so far forwards of the ricasso...I was actually quite surprised when I compared it to the grip of the shorter-bladed Paramilitary 2:
    In contrast the handle of the Para 2 feels huge and you could be forgiven for thinking that the blade of the Para 2 is larger (more so in your hand than in these photos), despite it being the smaller of the two blades. With the Street Beat you are getting a heck of a lot of cutting edge in a very compact package.
    Here is a size comparison with two well known Spydies (top to bottom - Paramilitary 2, Street Beat, UKPK):
    I have to say I've been getting along very well with this blade design. I really love the spine jimping and the extraordinary control this gives you over certain types of cuts. It really feels like an extension of the hand. The full flat grind makes this a nice deep slicer all the way to the relatively thick spine and the clip point is superbly done, leaving you with a fine tip that still inspires confidence in it's strength.
    The blade is VG10 and with the exception of a slightly uneven edge grind on one side it is beautifully finished. I'm sure everyone is familiar with VG10 and it's abilities. It isn't my favourite blade steel by a long shot, but it still takes a screamingly sharp edge. I just find that I don't get the retention from VG10 that I've found in other 'standard production' steels such as S30V and N690Co. Still, the silver lining is that it sharpens up in no time at all! This is a bit of the steel snob coming out in me though and honestly the VG10 of my two regularly used Spyderco Urbans has performed more than admirably over the last few years. The blade is part of a single piece of steel, full tang nestled between two micarta scales, double pinned.
    It's a solid, well built handle and feels like it will stand up to a lot of punishment. The micarta is completely smooth and looks beautiful. Texturing really isn't necessary due to the ergos of the handle locking you in place anyway. As you can see the handle also features a lanyard hole, about a millimetre wider than the one found on the Gayle Bradley but still a fair bit smaller than a Para 2 or Manix 2. It is very functional and will happily take a single strand of 550 cord, I just prefer a bit more room in case I want to thread a loop of 550 through.
    Just a word on fit and finish here...the knife is stunning and I am very pleased, however despite the handle scales being perfectly aligned with the tang, they are not symmetrical and the rear end of the handle is noticeably thinner on one side:
    This doesn't affect performance for me and I purchased my Street Beat as a user, not a princess, so I'm happy...it does however leave room for improvement as I like to swoon and purr over a flawless knife as much as the next guy! To any other Street Beat owners out there, I'd be interested to know if this is just something that slipped past QC or if these are simply acceptable variations in handle scales?
    The Street Beat comes with a Boltaron sheath with the G-clip fastening system and I am very impressed. The quality of the sheath is excellent and it fits the knife perfectly with no hint of any rattling.
    The G-Clip is adjustable via two screws (T10 torx) for inverted, vertical, forward cant, rear cant and horizontal carry. I prefer vertical carry at my side as I find following the body's profile stops me from snagging the handle.
    Here is the sheath in the vertical position clipped to a 5.11 TDU belt (1.5'' wide):
    The sheath rides comfortably under or over a shirt and is very accessible one-handed - it does not flex at the clip or slide along the belt line when attempting to retrieve the blade (like some sheaths I have found that require a second hand to steady the sheath on drawing).
    The G-Clip is extremely secure and isn't going anywhere; it takes a concerted effort to remove it intentionally, let alone by accident. As for blade retention this sheath is excellent. The blade locks into the sheath extremely securely, yet somehow drawing out the blade is buttery smooth. In fact it is that smooth that I cannot overcome my paranoia and I have added a loop of 550 cord as a safety measure. This is most likely entirely unnecessary but I find it puts my mind at ease if I am running/climbing etc. whilst wearing this sheath (especially if I was carrying inverted).
    It is just a tiny loop of cord threaded through the sheath that when pulled taut allows the blade free movement, but if left loose against the choil prevents the blade from leaving the sheath:
    Works like a charm and can be kept on the other side of the handle when the extra reassurance isn't needed or for when you don't have the time to keep pulling the cord taut before drawing. It puts my paranoid mind at ease anyway!
    All in all I'm thoroughly impressed with my first fixed blade from Spyderco and this makes a fantastic EDC sheath knife. I've found it to be particularly handy for food prep and think that this would make for an invaluable backpacking/camping knife. In fact it looks a lot like a miniature kitchen knife (albeit cross-bred with a Bowie!) and the deep choil really makes this great for chopping board type jobs.
    Along with it's great control for food prep duty I've also found that the full tang VG10 is very strong and very capable for more general outdoor use as well. It's a very tough little customer.
    Well, those are my thoughts on the street beat up to now. It's great design that really shines through how comfortable and intuitive this blade is to use. A top little sheath knife that has a great deal of cutting edge for such a small thing in the hand.
    I hope someone finds this useful
    Cheers for now,
    Uke.
    This article was originally published in forum thread: My First Spyderco Fixed Blade - Fred Perrin Street Beat started by Uke View original post
  • Sponsored Links...
  • Recent Forum Activity
    avoidspam
    What EDC are you carrying today?
    Thread Starter: avoidspam
    Thought I'd give this a go. Sorry if it's been tried before but I quite like the version on the other side of the pond. Everyone gets a bit creative with their camera's... Plus it's a nice opportunity to see what's out there....:) Sam
    Last Post By: ted2 Yesterday, 08:46 PM Go to last post
    Albert E
    Birds,bugs etc,around us!!
    Thread Starter: Albert E
    Hi!!We all see and sometimes take pictures of animals around our house,or during our travel vacations!!Here some!!Maybe you have a few from your area too!! A mantis in my garden.
    Last Post By: Albert E Today, 02:32 PM Go to last post
    Celtic Dragon
    Lets see your rifles?
    Thread Starter: Celtic Dragon
    As mine is still in the smiths (and has been for 6 weeks and no end in sight) The parts I have here are being fantasy pimped :D For those results you'll have to wait a few days. In the mean time to aliviate my suffering, lets see yours :D be it pcp, springer, rimmie or centrefire.
    Last Post By: John56 Today, 01:40 AM Go to last post
    Simon G
    Let's See Your Pistols
    Thread Starter: Simon G
    So, in the "let's see your rifles" thread, Rapidboy suggested a pistol thread. And as we always listen to the mods on here, let's give RB what he wants! (As opposed to what he needs!:D ) For UK mainland residents, obviously muzzle loaders and air. But for our friends in the not so discriminated...
    Last Post By: johnbaz Today, 12:42 AM Go to last post
    gruffalogriff
    Opinel Mod
    Thread Starter: gruffalogriff
    Modified this Openial No8 for my daughter. She found an antler last year while we were walking a Munroe in the Scottish highlands so i used a bit of that for the handle. Turned down the collar end on the lathe to fit the Openial hardware slotted the handle by clamping it in the woodworking vice and...
    Last Post By: gruffalogriff Today, 10:20 AM Go to last post
    Abyrvalg
    Laminated...
    Thread Starter: Abyrvalg
    This knife I made with a wonderful laminated blade made by my friend Alessio Salsi. I really like the look of this steel and i think it looks better than any Damascus... So, blade core is high-carbon "white steel" and sides are non-hardenable soft steel, 11 layers on each side. Handle and...
    Last Post By: Abyrvalg Today, 03:06 PM Go to last post
    polecat
    Bigger Bowie with Hamon.
    Thread Starter: polecat
    Been Forging out a 10 inch Bowie style blade and got around to starting the polishing today, needs alot more work yet but its starting to look the part now. Think I finally understand how to set up the Hamons on this steel, but getting the best from the polishing is hard work. Not easy to...
    Last Post By: polecat Today, 08:14 PM Go to last post
    BGC_Tom
    Overcoming loctite
    Thread Starter: BGC_Tom
    Hi all, So I recently bought a Bradford Guardian 3, along with a pair of ‘3D’ micarta scales to replace the G10 ones. The problem is, when I came to take the old scales off I just could not budge the screws! I’ve already broken one driver bit (one of those two-prong ‘spanner’ bits) and still...
    Last Post By: PuukkoJim Yesterday, 09:43 PM Go to last post
    camperman
    Japanese boning Knife
    Thread Starter: camperman
    Here is my idea of a Hankotsu boning knife. Ironwood scales. 12c27 steel.
    Last Post By: tomancik Today, 07:47 AM Go to last post
    surfer
    A new "Wanderer" with copper and brass
    Thread Starter: surfer
    Hello, I just finished this 10cm Wanderer! 10cm blade from 1.2442 at 61HRC, silver soldered guard from brass, spacers from aluminium, fiber, copper, micarta and leather, pommel from AAA sambar and copper with a 7mm Remington Mag. cartridge.
    Last Post By: Wrangler Today, 04:51 PM Go to last post
  • Alexa
    Review britishblades.com on alexa.com
