• Belt pouch by box construction - Tutorial
    So, having been asked to do a WIP on a simple leather belt pouch, I spent this evening with camera peering at me as i worked....
    Now folks, this is just my take on it, I am completly self taught as far as leatherwork is concerned but I have been doing it as a hobby on and off for about 15 years now. This is the methodology that works for me.
    If I am starting a prototype, I will usually play with graph paper first and design by drawing.
    This particular pouch is for a 2oz tobacco tin based survival kit. So first we need the dimensions of the tin, in this case 110mmx80mmx25mm. This gives us the basis for the front of the pouch, though we have to add a bit for stitching, 5mm per side. We also dont want the tin to be too tight in the pouch, so lets go for 90mm wide and 110mm tall. This should put the tin poking out very slightly from the top - gives us something to grab hold of. The side tabs also need a stitch allowance so we make those 30mm. The base must match so that also is set at 30mm. The back matches the front so we know that size too. Now the flap. We know the length of the top of the flap, 30mm, but we want the width a bit wider than the pouch so there is a nice overlap so add another 5mm each side, continuing to the front flap. The front flap can be any length you want but I like the rule of thirds and curves, so I made it about two thirds of the length and nicely curved. Then little details are added such as radiusing the back corners of the flap, just as finishing touches.
    When I am happy with the design I transfer it to thick card or mount board if I want a more permanent pattern.
    This is then cut out and any fold lines are scored to aid folding.
    If at this stage it all appears to work and looks they way you expect then the pattern can be transferred to the leather, flesh side so any mistakes with the pen dont show, and cut out. I have also punched the holes for the popper, and prepared a strip for the belt loop.
    [/QUOTE]
    Quote Originally Posted by bardster View Post
    To help the leather fold in the right place and have the corners look crisp, there are a couple of options. a 'V' gouge works very well, but in this case I thought the leather a little thin, so I used a heated creaser on the flesh side.
    The next stage was to mark the stitch holes for the belt loop and for this I used a stitching chisel.
    Because this is a box pouch, we want the edges to meet at 45 degrees so we bevel all the edges that will be joined. On thicker leather I would use a french edge skiving tool, but in this case a standard no 3 beveler does the job.
    All exposed edges are then slicked and burnished with gum tragacanth
    Then, using a stitch marking wheel and awl, all of the stitch holes are marked and made. I havn't used a stitch groover for this project as we will be using a decorative surface stitch.
    At this stage all the preperation is done so we can now colour the leather, I chose to do this one in black - bit of a mistake really as it made the pictures less clear
    I have started using the eco-flo pro water stains and am having very good results with them.
    The stain is applied to a sponge and rubbed into the leather untill its fully absorbed.
    Once the dye has fully dried, I then seal the leather. I use various products depending on application but in this case chose to use snoseal, I like that it is beeswax based and it does a really nice job and isn't too shiny.
    Now we have our pieces coloured we are ready to start assembling.
    First we have to sew on the belt loop, and fit the hardware, in this case a popper. We do it now as if left till after sewing up the main pouch we wont have access to the inside
    There are numerous ways of sewing the sides of the main pouch, this project started as an experiment of the different methods. I have used lace as well as thread and different styles of stitch. What seems to work best so far is a simple cross stitch. So starting at the bottom I comence stitching using two needles.
    Once I have completed one side of the base I then do the other before going up the side, as it gets tricky to sew the second base if one side is fully closed.
    Once thats done I then complete the first side, with a final loop stitch at the top,
    and then the second side of stitching.
    [QUOTE=bardster;2075614]and a final buff with a soft cloth and its done.
    And a final group shot, thanks for looking.
    This article was originally published in forum thread: Belt pouch by box construction - WIP started by bardster View original post
  • Sponsored Links...
  • Recent Forum Activity
    Albert E
    Birds,bugs etc,around us!!
    Thread Starter: Albert E
    Hi!!We all see and sometimes take pictures of animals around our house,or during our travel vacations!!Here some!!Maybe you have a few from your area too!! A mantis in my garden.
    Last Post By: Albert E Today, 01:26 AM Go to last post
    SilverJohn
    British Military Kukri
    Thread Starter: SilverJohn
    Hi there, I never really had much of an interest in knives beyond a trusty SAK or Leatherman until around May last year. That was when I first spotted some interesting modern kukri and learned a bit about the range of styles within kukri (hence my handle, though I've got noting to do with Tora,...
    Last Post By: spiraltwista Yesterday, 04:19 PM Go to last post
    zuludog
    North West Knifemakers Meetup
    Thread Starter: zuludog
    NORTH WEST KNIFEMAKERS MEETUP 28 & 29 May 2016 Rochdale Camping available Come for either or both days Details to be posted later Please reply if you are interested, so we can get an idea of the numbers
    Last Post By: dimmaz88 Today, 12:49 AM Go to last post
    Stew
    Forum knife - Phase 3 sign up.
    Thread Starter: Stew
    Good morning. This is the sign up thread for the forum knife, phase 3. Picture courtesy of Leeroy37 Details as per here: http://www.britishblades.com/forums/showthread.php?204730-Forum-knife-delivery-details
    Last Post By: hurrand Yesterday, 11:56 PM Go to last post
    gary.mitch31
    ZT 0801 Copperhead seized
    Thread Starter: gary.mitch31
    Just wondered if anybody could offer any advise please. I had been looking for one of the copperhead Ltd edition knives for quite some time and finally found one advertised on Facebook a couple of months back. Eagerly, I paid my money and awaited its arrival. Being honest, I didn't envisage any...
    Last Post By: Noddy Yesterday, 07:24 PM Go to last post
    Tettley
    Spyderco Urban or UKPK?
    Thread Starter: Tettley
    Im looking for my first penknife in many a year and need some advice. Ive decided on a Spyderco and would like it to be UK carry legal, so have now narrowed it down to these 2. Any recommendations on which one? Ive seen a few reviews bur still cant decide. The urban seems less available and higher...
    Last Post By: snowblink Yesterday, 08:45 PM Go to last post
    swoosh
    Dark Night in the woods. Pic heavy.
    Thread Starter: swoosh
    Out again with my son, different camp spot this time, next to a huge fallen tree. Couple of new knives with us, response pack contents, and a bench/seat, another great night out. Hope you like the pics. Tarp up this time, wasn't sure of the weather, windy too so helped keep the breeze off, also...
    Last Post By: dimmaz88 Today, 12:53 AM Go to last post
    Hloening
    2x72 or 2x60?
    Thread Starter: Hloening
    Hello! I've been getting into knife making an I thought it was time to step it up from bench grinders and files and build myself a belt grinder. So far I have purchased most of the relevant things required to build one however I am have a quandary... Should I build a 50mm x 1525mm (2" x 60")...
    Last Post By: FGYT Yesterday, 10:24 PM Go to last post
    Jamb0
    Metal suppliers and heat-treaters around Glasgow, recommendations?
    Thread Starter: Jamb0
    Hi folks, I am just starting out in the exciting craft of knife-making and so far this site has been my Open University. So helpful. I have my workshop cobbled together and my first design for a Sgian Dhu ready to go. I've priced up some O1 from some local metal shops and I'm wondering where...
    Last Post By: shing Yesterday, 11:41 AM Go to last post
    RVJ87
    Shipping knives in the uk? Advice greatly appreciated.
    Thread Starter: RVJ87
    Hello all, I know that this topic has already been discussed on these forums, but I can't quite seem to find exactly what I'm looking for. I was wondering if people out there who have experience with this sort of thing would mind possibly giving some advice on this. I suppose what I really...
    Last Post By: Corso Yesterday, 12:25 PM Go to last post
  • Alexa
    Review britishblades.com on alexa.com
