Olight SR90 Intimidator Review
    Orlight SR90 Intimidator review.
    2200LUMENS! Was the battle cry that registered on my Jamie radar. Easily the most affordable eye scorcher I had seen to date.
    I like a good range of torches from the relatively low powered Malkoff M30F to my current high lumen monster the well known Ultrafire WF-1000.
    After checking the money fund…..”please babe can I just have one more torch!?” I pre-ordered one from flashaholics www.flashaholics.co.uk . I had never used them before but they were easy to use and Antony let me know when it had arrived and was being shipped out to me.
    Full specs from Olight
    http://www.olightworld.com/product_show.asp?id=174
    First Impressions
    On opening the box this morning I was pleasantly surprised to find a well bubble wrapped metal case bearing the legend “Olight”. Inside I found what has to be one of the biggest torches I have ever seen.
    Provivded in the case is the LED head assembly, battery pack, charger, strap, 2 spare o-rings and instructions. To install the battery pack you unscrew the protective cap and attach to the head. I was pleased to see there was ample grease on all threads which made the process stiff but easy. I was surprised to find that there was no protective cap on the head assembly. If you provide a cover for the battery pack to keep the muck out doesn’t it make sense to do the same for the bit It screws into?
    Review
    Right down to it.
    This is a BIG torch, no arguing. It weighs in at a hefty 1584g according to my kitchen scales. This is nearly 100g heavier than the claimed 1500g. It feels big in the hand and quite front heavy. There is a large and thick looking lens with what is billed as a ‘striking bezel’ at it’s best it’s 6mm deep so I don’t know what you are expected to strike with it, better just to club them with it!
    The LED
    There is a lot of heatsink around the very smooth refelector. This is designed as a thrower no question. Moving further back you find the power switch. It stands a little proud and has a nice soft click to it. Quite small though so operating with gloves could be a problem.
    The user interface is press once- high, press again and hold to switch down to low mode. A quick double press activates the strobe. It also has a memory so it turns on at the last setting you turned it off at
    The grip on the battery pack is chunky and deep and provides plenty of grip without feeling like it is going to strip the flesh from your hand.
    Moving to the back of the torch we find the charging and battery life lights. A quick press of the white switch gives you a 5 second reading from the 4 LED’s.
    4 led’s indicate 85%+ power remaing
    3 indicate 60-70%
    2 40-60%
    1 20-40%
    No lights indicate less than 20% power remains and needs charging.
    When I tested this morning all 4 lights came on immediately. I did decide to top it off though. An intelligent charger is included very reminiscent of a laptop power supply. Charging is shown by a red LED that turns to green when fully charged and I assume switches to trickle charge.
    On a recharging note the instructions say the batteries are “just like those in a laptop computer; their service life will be optimized if you charge your light after every use”
    Also they recommend if the light is not used regularly then charge the pack every 3-4 months “without fail”.
    One main thing I don’t like about is the cover for the charging socket. It is made out of what feels like a very thin rubberised cover. It feels very soft, pliable and is quite difficult to remove. I have little doubt if there is one thing that will break on this light this is it.
    2 strap mounting points are also on the body and look like they are brass. They are chunky and look very much up to the task. They rotate 360 degrees. the strap provided is good quality with 'Olight' embroidered into it.
    Modelled by my lovely wife
    Close up of the stitching
    Overall I like the whole package. There are a few little niggles but they are only small. The light feels well built and engineered and fit and finish are overall very good.
    Comparison between some well known lights
    Surefire 6P, AA minmag, 2D Maglite, SR90
    Lens Sizes
    Beamshots
    OK so you have been patient enough to read through my drivel so we’ll get to the parts you want to see.
    I decided to try to get a “real world” effect to the beamshots. Meaning to try to show in the picture what is seen with the human eye. It is all too easy to overexpose the shot and make these things look like a lightsabre or laser cannon.
    Technical stuff
    Camera- Nikon D300
    Focal length- 35mm
    Manual mode
    Manual focus
    ISO- 200
    f-stop- f4.8
    Exposure- 4 seconds
    Mounted on a tripod with a cable release
    I used 4 other lights i use on a regular basis
    Surefire 6P with Malkoff M30W (warm tint)
    Surefire 6P with Malkoff M60
    Wolf-eyes Explorer MC http://www.heinnie.com/Flashlights/W...p-97-299-4082/
    Ultrafire WF 1000-L
    This is the best i could do for a control shot, the weather has just been too lousy to get a daylight shot. This is the view from my front garden.
    The distance from camera to the gates is 62metres
    The telegraph pole behind is 81metres away
    The small grey board you can see is the back of a sign, that is 113metres away
    So
    Malkoff M30W
    Malkoff M60
    Wolf-Eyes (on high)
    Ultrafire (on high)
    SR90 (on high)
    VERY impressive i think you'll agree
    I couldn't resist a bit of beamshot porn
    30 second exposure
    Hope that gives most of you an idea of just how powerful this light is. For the price this is an unbeatable package in my opinion.
    Anything you think i should add or you want to know feel free to ask.
    Thanks for looking
    This article was originally published in forum thread: Olight SR90 Intimidator Review started by ArkAngel View original post
    Comments 2 Comments
    1. Chris Smith's Avatar
      Very good review of an amazing product. Not sure where it sits in the buying queue, but it is there somewhere soon. Thanks.
    1. bigreddog's Avatar
      Hells Bells, thats a monster. The Fenix on my keyring feels strangley inadequate now!
