• Old Hickory Skinner to Nessmuk conversion
    This morning I received two Old Hickory Skinner knives from Schwert in a trade ( ) and must admit I’m impressed to bits with them. The original reason for wanting them was to make George Washington Sears “Nessmuk” style field knives from them. They have 1095 Carbon steel 7” skinning blades, roller marked, with a tip that turns up high to a full 90 degrees –these are impressive blades. The handles are a dark hardwood and stamped Old Hickory (no…they aren’t hickory…). OH is a trade name of Ontario Knives (confusingly a US manufacturer.) A pleasant surpise was the blade grind -it's not hollow ground but rather a sabre-grind with flats like a Scandi. I thought I would have to do that myself but its already done.
    These knives cost peanuts in the US (mine were on special for $6.47 (yep - $6.47!), though a bit more time, effort, co-operation and money was required before they bumped on the doormat in Fyvie (Thanks again S! )
    I was going to rehandle and regrind these to make a pair of fairly fancy Nessmuk’s, but thought I’d see just how simple the conversion could be since the existing handles have a very “period” feel for turn of the (20th) century knives. So #1 at least is a bare minimum with its original handle. I might curve the blade clip just a little more than it is right now, but better too little for now than straight to too much. Removing steel is easy, putting it back is…er…not.
    Schwert suggested I photograph the conversion, and that’s what this thread is. My camera sadly is a bit basic –but the gist should be clear. Unfortunately my macro setting doesn’t allow enough stand-off to get the whole knife in on macro, while the non-macro has a closest focus of about 3’. Still, here goes.
    Right, here is the blade of the Old Hickory Skinner against a Dale Chudzinski Nessmuk (thanks SSJ ) that I’m using as my reference model.
    Here’s the Nessmuk lying on top of the Skinner and you can see how the Skinner gives enough steel to cover the Nessmuk shape.
    I’ve just put a piece of masking tape on the Skinner blade and quickly drawn two lines. A straight one for the first cut and a curved one to get the “final” shape impression.
    The straight cut will be made with a diamond cut-off wheel in a budget B&Q Dremel wannabe. To preserve the heat treatment throughout I’ll cut it in a bucket lid filled with cold water. That’s the grubby round thing…
    Halfway-ish. No sparks, no heat. Fair bit of light water spray but a very painless operation for me (the patient might beg to differ))
    Hmm…a bit for the tooth fairy .
    Scimitar anyone? That’s the chop cut complete. Took all of 10 minutes with a few stops just to be on the safe side but nothing got even remotely warm and the cutting wheel lasted.
    Here’s the first cut against the DC Nessmuk for comparison.
    And here’s the curve line for grinding to final shape. Again just masking tape and pencil.
    To grind the blade I have a cheap (Ł24.95) Wet and dry whet/grinder from Wickes. I use this a fair bit for cold chisels and axes and now for blade profiles (though this isn’t the first….umpteen Opinels, a Shing Skinner and several other scandie blades and tangs have fallen to it so far). Sorry about the focus…
    The slow wet wheel is really quite coarse but this also keeps things cool…
    Right, curved grind complete. I dressed the spine a bit with a medium lansky stone that gave me a finish to match the original untouched spine. This is the end of the simple conversion. Total time on the bench about an hour. No HT complications and no fancy finishing. Its obviously not in the same league as DC’s work but I have a suspicion GWS might have approved.
    I have another Skinner and might treat this one to a new handle…then again …
    I’ll leave you with a before and after shot. Then start thinking about a sheath.
    This article was originally published in forum thread: Old Hickory Skinner to Nessmuk conversion started by Basemetal View original post
    Comments 6 Comments
    1. luckylee's Avatar
      luckylee -
      i loved reading, and looking at the pictures of this article, and the finish, great stuff mate.
    1. grangerknives's Avatar
      grangerknives -
      Danny, you're pretty clever... for a biped. You would enjoy any of the books by M. H. Cole. He was a wonderful illustrator, an expert on knives and a BLADE Magazine HOF'er. I will post some of his pics. Sadly his books are rare due to being mostly out of print. And when they are available, they are usually pricey.
    1. nowhereman's Avatar
      nowhereman -
      Good one mate - I've always had a soft spot for nessie's, but have yet to make one.. Now I've seen this I'll be looking for a ness shape in every blade I see! BTW i'm impressed with the cutter -
      Regards
      Dan
    1. Basemetal's Avatar
      Basemetal -
      Quote Originally Posted by nowhereman View Post
      Thanks Dan, it was just a cheapy -nothing special. Dremel type cut-off disks would do the same though you'd use a few. Main thing was just to keep the blade cool, hence doing it in water.
    1. puukko3883's Avatar
      puukko3883 -
      I hope this doesn't double post.
      Basemetal, a very neat conversion !
      How about fine sanding the handle and hitting it with some linseed or Danish oil ?
      Or perhaps buffing the sides of the blade with a bit of polishing compound ?
      I think this would give your conversion a very nice finished look.
      It will be interesting seeing the sheath you come up with for this ?!
      Basemetal -
      Hi and thanks,
      I did smooth and buff the handle on the one of these that I use. But I do like the patinated look the CS blade has taken on. You can see the sheath I came up with in another thread/article here.
  • Sponsored Links...
  • Recent Forum Activity
    avoidspam
    What EDC are you carrying today?
    Thread Starter: avoidspam
    Thought I'd give this a go. Sorry if it's been tried before but I quite like the version on the other side of the pond. Everyone gets a bit creative with their camera's... Plus it's a nice opportunity to see what's out there....:) Sam
    Last Post By: ted2 Yesterday, 08:46 PM Go to last post
    Albert E
    Birds,bugs etc,around us!!
    Thread Starter: Albert E
    Hi!!We all see and sometimes take pictures of animals around our house,or during our travel vacations!!Here some!!Maybe you have a few from your area too!! A mantis in my garden.
    Last Post By: Albert E Today, 02:32 PM Go to last post
    Celtic Dragon
    Lets see your rifles?
    Thread Starter: Celtic Dragon
    As mine is still in the smiths (and has been for 6 weeks and no end in sight) The parts I have here are being fantasy pimped :D For those results you'll have to wait a few days. In the mean time to aliviate my suffering, lets see yours :D be it pcp, springer, rimmie or centrefire.
    Last Post By: John56 Today, 01:40 AM Go to last post
    Simon G
    Let's See Your Pistols
    Thread Starter: Simon G
    So, in the "let's see your rifles" thread, Rapidboy suggested a pistol thread. And as we always listen to the mods on here, let's give RB what he wants! (As opposed to what he needs!:D ) For UK mainland residents, obviously muzzle loaders and air. But for our friends in the not so discriminated...
    Last Post By: johnbaz Today, 12:42 AM Go to last post
    gruffalogriff
    Opinel Mod
    Thread Starter: gruffalogriff
    Modified this Openial No8 for my daughter. She found an antler last year while we were walking a Munroe in the Scottish highlands so i used a bit of that for the handle. Turned down the collar end on the lathe to fit the Openial hardware slotted the handle by clamping it in the woodworking vice and...
    Last Post By: gruffalogriff Today, 10:20 AM Go to last post
    Abyrvalg
    Laminated...
    Thread Starter: Abyrvalg
    This knife I made with a wonderful laminated blade made by my friend Alessio Salsi. I really like the look of this steel and i think it looks better than any Damascus... So, blade core is high-carbon "white steel" and sides are non-hardenable soft steel, 11 layers on each side. Handle and...
    Last Post By: Abyrvalg Today, 03:06 PM Go to last post
    polecat
    Bigger Bowie with Hamon.
    Thread Starter: polecat
    Been Forging out a 10 inch Bowie style blade and got around to starting the polishing today, needs alot more work yet but its starting to look the part now. Think I finally understand how to set up the Hamons on this steel, but getting the best from the polishing is hard work. Not easy to...
    Last Post By: polecat Today, 08:14 PM Go to last post
    BGC_Tom
    Overcoming loctite
    Thread Starter: BGC_Tom
    Hi all, So I recently bought a Bradford Guardian 3, along with a pair of ‘3D’ micarta scales to replace the G10 ones. The problem is, when I came to take the old scales off I just could not budge the screws! I’ve already broken one driver bit (one of those two-prong ‘spanner’ bits) and still...
    Last Post By: PuukkoJim Yesterday, 09:43 PM Go to last post
    camperman
    Japanese boning Knife
    Thread Starter: camperman
    Here is my idea of a Hankotsu boning knife. Ironwood scales. 12c27 steel.
    Last Post By: tomancik Today, 07:47 AM Go to last post
    surfer
    A new "Wanderer" with copper and brass
    Thread Starter: surfer
    Hello, I just finished this 10cm Wanderer! 10cm blade from 1.2442 at 61HRC, silver soldered guard from brass, spacers from aluminium, fiber, copper, micarta and leather, pommel from AAA sambar and copper with a 7mm Remington Mag. cartridge.
    Last Post By: Wrangler Today, 04:51 PM Go to last post
  • Alexa
    Review britishblades.com on alexa.com
