Results 1 to 2 of 2
    Aug 2009
    Ireland
    How to remove the heating element from a hair dryer?
    How do you remove the heating element from a hair dryer, is there a wire that you can snip? I can only access the the handle of the hair dryer and is there any wire that I can snip in the handle?
    Cheers,
    Mar 2007
    perth australia
    Re: How to remove the heating element from a hair dryer?
    If you are thinking of using the dryer for a forge blower you can use it as it stands. I did this in a charcoal forge and used it for a while before I was able to get a gas forge. I used a standard dimmer switch to control the speed and it seemed okay (heat and speed were simultaneously adjusted).
    Good luck with it,
    Jim.
    Have a go ! You may well surprise yourself.
