View Poll Results: Does this help?
Voters
24. You may not vote on this poll
  • Yes!
    10 41.67%
  • No!
    9 37.50%
  • Maybe?
    5 20.83%
Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
  1. #31
    Nov 2010
    cornwall
    Re: Formula to work out grinding angle for blade or bevel
    i dont think useing a jig makes it any less hand made the same as useing a grinder , drill press , lathe , buffing machine or etcher . its just another tool in some ones tool box to aid the process along . to be fully hand made you would have to start by smelting your own steel like a few folks on here have done
  2. #32
    May 2009
    Cranborne Dorset
    Quote Originally Posted by Merwe knives View Post
    Naahh, I grind freehand, soon realised it's the way to go unless I build a jig for every knife I make. I 'eye' the bevels
    It's called 'handmade' right?
    Relly Ive just used the same bit of 2" angle and a pair of mole grips for all blades flat and Scandi and now Hollow grind (minor alteration for hollow mainly cos i cant drop the Table on my grinder) done a few hundred now over the last couple of years all shapes
    would still like to learn Free hand as it does have some advantages and uses
    ATB
    Duncan
    Dorset Woodland Blades : Sharp is not an optional Extra
  3. #33
    May 2012
    South Africa
    Quote Originally Posted by bones61 View Post
    Not what I'm saying, calculating angles as per OP would only be handy when using a jig with precisely adjustable angles or using CAD driven CNC machining. So I voted "no" since it would not help me. Because I don't use a precision jig or CNC machine there will be measurable inconsistency in my grinding, like I can see on an old Puma White Hunter I have (pre Puma's switch to CNC'ing). This I feel is excuseable because it's 'handmade', same as the slight irregularity in a maker's stamp is excusable unless he uses a laser engraver.
    I cannot get a jig around the curves of a Bowie or a "Bearclaw's" recurve grind so I decided it would take me less time to learn to grind freehand than it would take me to figure out a jig system that'll allow me the same freedom at the same speed.
    I envy the guys who do forging and even more so the guys that make their own steel and that's not because it looks like hi-tec metallurgical CNC'd knives.
  4. #34
    May 2010
    Brockville, Canada
    Math scares me
    although good for some, just not for me I suppose....
