Results 1 to 6 of 6
Thread: Storage of ferric chloride help
09-02-11, 09:31 AM #1
Could you give me advice on how I should store ferric chloride ?
What do you use to store yours ?
I have been looking for tall glasses like spagetti jars , waste pipe with blanking ends so far.
I preferably would like a 12 inch + container of some sort.
cheers.
09-02-11, 02:19 PM #2
Re: Storage of ferric chloride help
I use a large kilner jar much like a spagetti jar. it has a large mouth opening and so far has been ideal. i have three one with ferric, one with bicarb and one with vinegar. i think they cost me about £3 each from a cheap cook shop. the plastic seals around the glass lid have been fine to date.
Regards
Brian
Why is it every time you hit the 'post' button you then see all your spelling mistakes??
09-02-11, 04:31 PM #3
in any thing not metal will work fine i do like plastic most as glass can easily break
ferric does get old and weak with time and old stuff will give a blurry etch so find a container suited in size for what your doing and mix as little as possible
Daniel Claville
Flames and Fire is forever my Desire, And my Desire shall bend the will of Steel
09-02-11, 05:10 PM #4
Ive made a 40" tank from a piece of downpipe, with a cap on one end, and a screw cap on the other. (and a matching one for bicarb) got all the bit from Travis Perkins.
I did use spaghetti jars, but its very easy to drop the blade into them and knock the bottom out
09-02-11, 06:27 PM #5
Glass, plastic or titanium!
When the etching became worse I used to test the specific gravity of it, then add water to put it right. It used to last for ages. I can't remember what the radings were though.*There's no more scientific basis for intelligent design than there is for the idea [that] an omniscient creature made of pasta created the universe - Justin Pope
Limited Edition? As in Franklin Mint?
09-02-11, 07:41 PM #6
That's exactly what I had in mind because I sort of remember that set up at Chris Grants place. I couldn't find the end caps anywhere and thought they were not being made anymore. Thanks for the heads up.
Many thanks to all who replied I have a better understanding of what's required now.
