Results 1 to 5 of 5
    Oatmeal Oasis
    TD5 alarm procedure for battery disconnect.
    I have a vague recollection of reading that there is some sort of procedure you can follow when disconnecting the battery on a TD5 landrover that stops the din and possible fob sync issues when reconnecting.
    Does anyone know if this is the case, and if so, what it is?
    BB Landy Collector
    Aug 2010
    Ascot
    Re: TD5 alarm procedure for battery disconnect.
    When I had my TD5 I found a mind of information on www.forum.landrovernet.com and having had a quick glance there are some threads on this subject. I am sure someone will be able to answer your question faster than you trawling thru the forum, but it was a mindfield of info. Hope that helps in a non-helpy sort of way ATB
    Oatmeal Oasis
    Thanks, a quick google got the owners manual which tells you how to do it!
    BB Landy Collector
    essex
    Hi Mojofilter, this is what says in my hand book,
    1. turn the starter switch on and then off, then remove the starter key.
    2.disconnect the vehicle battery WITHIN 15 SECONDS. (if it is not diconnected within 15 seconds ,the back up siren will sound immediatly the battery terminals are disconnected).
    hope this helps, Alan.
    my typing tooo slow
    Oatmeal Oasis
    Quote Originally Posted by alan-g View Post
    my typing tooo slow
    Thanks all the same for taking the time to look mate, I appreciate it!
    BB Landy Collector
