Results 1 to 6 of 6
    Jul 2011
    Herts
    Wink DIY belt grinder?
    I'm building my own belt grinder and was just wondering if some one could answer! Should I attach the belt straight to the drive wheel or should I Go with the Shaft Pillow Block then a contact wheel?. Any help would be greatly appreciated and any other advise. Ps love this forum keep up the good work. 
    Jul 2011
    Dorena Oregon USA
    Re: DIY belt grinder?
    you can go ether way. I have built three so far and the first two were pillow blocks the last direct drive.
    if you use pillow blocks, you can put step pulleys and have a cheap variable speed. if you go direct drive you are eather stuck with a single speed or will have buy a pricier VFD.
    it all comes down to money
    Erik
    Jan 2010
    Israel
    I'm planing to build one right now and I can not see why not attach the wheel straight to the motor wheel... see here (from 3.57 ):
    http://www.youtube.com/watch?v=DupWsV-iiys
    Peak District
    Might be worth looking in the Big Boys Toys forum
    Jul 2011
    Herts
    thanx for the advise peeps andil look into the advise you all have offered
    Jul 2011
    Herts
    cheers guys much appreciated.
