Results 1 to 12 of 12
    Apr 2011
    lincs/notts
    swap my nickel 200/201 for your..
    gentlemen i bought some pure Nickel Sheet, .062" (1.6mm), 6x2" (15x5cm) from canada it stands me at 20 im not skilled enough to use it and rather than waist it id rather swap it for a similar value of steel i can use .id like more W1/W2 or 15n20 as i can defo use both.
    anybody fancy it ?
    mick its labeled nickel 200/201 (the stuff you have or had from the states)
    all the best , matt . .
    Apr 2011
    lincs/notts
    Re: swap my nickel 200/201 for your..
    nobody brave enough ?
    Dec 2006
    uk
    doubt its to do with brave, more to do with the fact the stuff should be gold plated at twenty dabs for a piece that size
    Apr 2011
    lincs/notts
    maybe your right but the way to look at it if your a thinking man is that i need W2 more than i need pure nickel !! that leaves you guys in the strong position !!
    Dec 2002
    Herts
    Unfortunately a thinking man will know that a piece 6x2" is barely enough for two layers in a small billet.
    Mick.
    Apr 2011
    lincs/notts
    same old, same old then .....
    well i will have to try the impossible !!
    at least i know its a hard material to work with and how it will behave , maybe with more resurch i can work out the bast way to use it !!
    iv done everything else the hard way why not this ?
    thanks gents anyway ..
    Nov 2007
    Denmark Fyn
    if you have realized that's its a bit too hard to work with atm. why not just save it for a year or two?
    Daniel Claville
    Flames and Fire is forever my Desire, And my Desire shall bend the will of Steel
    Apr 2011
    lincs/notts
    thats it dcl .
    i have in the corner of my mind an idea to laminate it with thick mild steel weld up the edges and let it sit in the forge til it alloys . leaving me with home made nickel /steel for core construction.
    or more complex and i dont know anything about it . put mild/carbon scrap in a crusible in my new furnice and once molted add some nickel again home made nickel steel .
    go on shoot me down ha ha ..
    tell me im a stupid boy !
    Jan 2010
    wales
    Quote Originally Posted by matt,simmons View Post
    I have an offcut of 75ni8 as tall as me x 1.6mm x 54mm, I'll swap it for your tiny scrap of Nickel.
    Apr 2011
    lincs/notts
    pi$$$ take ?
    if not happy days your on .
    Jan 2010
    wales
    pi$$$ take ?
    I don't think I could be that mean- The idea of you resorting to casting your own steel tugged at my heart strings
    pm me your address and we'll get it sorted.
    Apr 2011
    lincs/notts
    arived today thank you nic very generouse of you .
    all the best matt .
