Results 1 to 12 of 12
    Nov 2011
    North West England
    Spyderco Manix 2 Lightweight Review
    Hello all,
    I've been waiting for these to become available this side of the pond for a while now. From the thread I posted before the weekend there seem to be mixed opinions on this incarnation of the Manix, based mainly on the co-polymer handle and it's 'toy-like' looks (http://www.britishblades.com/forums/...ent-blue-at-HH!). Well, I couldn't help pick one up and it hasn't left my side since the weekend, so here's what I'm thinking so far (this is quite a long one with lots of pics so please bear with me! )...
    ...The first thing that I noticed was that the handle appears far darker in person and almost matt (i.e. not as translucent as I'd expected) in some lights. The idea of the 'toy-like' appearance never bothered me anyway as I'd planned on hammering this knife a bit so looks weren't important, however I've been very pleasantly surprised and think the Manix 2 lightweight is actually pretty darn attractive.
    Here are the stats from Spyderco:
    length overall: 8 " (203 mm)
    length closed: 4.67 " (119 mm)
    blade thickness: .118 " (3 mm)
    blade length: 3.39 " (86 mm)
    blade steel: CTS BD1
    cutting edge: 2.87 " (73 mm)
    handle material: FRCP
    weight: 2.85 oz. (81 g)
    This certainly lives up to its name as 'lightweight', a full 62g / 2.15oz lighter than the original G10 fully lined production version! This knife is incredibly light for its size.
    My scales read the lightweight at 82.82g:
    My G10 Manix 2 (even with the milled liners of the sprint runs) weighs in well over my scales' 100g capacity (approx 120g):
    In fact the Lightweight is closer to the weight of a UKPK at 67.83g than a G10 Manix 2:
    Now I turned my nose up at the FRN UKPK lightweight for quite some time (I am a bit of a G10 snob!) but was very pleasantly surprised. There were some compromises, such as the lack of a full backspring resulting in weaker tension, a hollow grind in CTS-BD1 as opposed to a full flat grind in S30V. I presumed the differences between the Manix 2 and its lightweight version would be comparably to the UKPKs, however I am actually finding that there seem to be less compromises in the case of the Manix.
    The weight difference of approx 15g between the UKPKs always seemed pretty negligiable to me and it was reasonably clear that its real purpose was to be a 'cheaper' alternative to the G10 UKPK. Nothing wrong with this and the UKPK lightweight has found its place in my rotation. However with the Manix 2 platform, the weight difference of 62g between the lightweight and the original production model is considerable. This 'lightweight' is still at its core what a Manix is renowned for; toughness and robusticity, and this feels like a Manix 2 purely designed to be 'lighter', not 'cheaper'...albeit with the exception of the blade steel.
    Manix 2 and Manix 2 lightweight, open and closed:
    The most noticeable difference is obviously the handles. The lightweight's 'fiberglass reinforced co-polymer' scales feel very strong, with a slight flex in the centre of the handle when pinched deliberately and tightly between the fingers. The Spyderco bi-directional texturing is flawless and makes the jimped and grippy design of the Manix 2 even grippier.
    Due to the lack of liners the Manix 2's trademark jimping has been recreated on the co-polymer scales...
    ...this works pretty well, not quite as aggressive as the original jimping but still very functional. There is a steel section running from the pivot of the knife to contain the locking mechanism as on the original Manix 2, however the lightweight version has a sealed back running the full length of the handle, utilising a co-polymer back spacer (similar to the construction of the Sage 3, giving the illusion of one solid handle). This back spacer seems to give more strength to the scales to go some way to make up for the lack of liners...
    ...as you can see, the dimensions of these knives are almost identical. The lightweight has a wire pocket clip as opposed to the original solid hourglass clip. On a knife of this size I prefer the look and feel of the original solid clip, however I presume that this again contributes to the weight difference. Despite the inverted attachment of this wire clip making it appear longer than that of a UKPK, the portion that sits outside the scale is actually the exact same size. It sits in the pocket at the same depth of the original Manix 2 and feels nice and secure. I have to say though that the original clip feels stronger to me...but then so does the orignial G10 handle with full steel liners, I guess these would be the compromises for the lighter weight! The lightweight is also pinned construction as opposed to screw-together. This means you won't be able to take it apart (although this would void your warranty anyway ). This also means that you cannot adjust the pivot, however I have a few Spydies now with the new bushing pivot system which means you cannot change the pivot tension anyway, despite having a screw together construction, so I don't really see this as a problem (although screw together construction does feel preferable, at least giving the option for warranty voiding mods and maintenance).
    Here are some comparison shots in the hand:
    I can honestly say that in the hand the lightweight feels just like a standard Manix 2...except lighter! Yes the handle doesn't feel quite as 'luxurious' as the G10 but it handles the same, it's a bit grippier on the sides, doesn't feel too blade heavy, and the lock up is as rock solid as ever. The caged ball bearing lock feels identical to the lock on the G10 models. This still feels like the robust Manix 2 that I know and love, albeit just not quite as tank-like. The handle still feels tough and up to the job, you just don't get the same feel that those nice thick G10 slabs and steel liners give you, but then this was always going to be the case.
    Fit and finish is excellent and other than a couple of small mould marks at the ends of the co-polymer scales the knife is flawless. Lock up is perfect with zero play in any direction, blade centring spot on, bevel grinds top notch and here I really have to mention the price...I picked this up for £72.49 and for what I've received I have to say this is the best value Spydie I feel I have ever purchased.
    Full flat ground and Golden made:
    For a Golden made Spyderco this feels like ludicrously good value, especially when you consider just how much knife you're getting. For me the only thing stopping this knife from being really special is the blade steel. Don't get me wrong, I like CTS-BD1 and have been very pleased with its performance on my UKPK lightweight, I just feel that the BD1 may be what gives this knife the 'budgety' feel...
    ...in my experience CTS-BD1 keeps a good working edge for a long time. The real difference that I noticed between the BD1 of my UKPK lightweight and the S30V of the other models was that the BD1 lost its 'razor edge' rather quickly. Very easy to sharpen though. For me however the Manix 2 lightweight makes up for this steel choice in a way that the UKPK lightweight never did; by being fully flat ground just like the sprint runs
    I know hollow grinds have their uses, but I love the FFG on the Manix 2 sprints and the hollow grind is what soured the original Manix 2 production models for me. I just find that the FFG lets me use the entire depth of the blade more effectively, which I find especially useful on a leaf shaped blade of this size.
    Now if I could only choose one or the other, I'd take a full flat ground G10 Manix 2 sprint run over the lightweight any day of the week. However in the wonderful real-world where we are free to have both, I do find my G10 Manix 2 just a bit too heavy/cumbersome for pocket carry when I'm wearing a light pair of shorts. Therefore, for me the Manix 2 Lightweight fills a niche perfectly. I've had this in my shorts since the start of the weekend (the weather has been really muggy here...too muggy for long trousers!) and have used it from the garden to the kitchen...
    After four days of reasonable use the BD1 is still slicing paper although not with the resistance free glide of a real razor edge. If you look closely you can see the rough, frayed edges of the paper strips here (the CPM-M4 of my tan Manix 2 still cruises through paper with ease after this level of use):
    All in all I think that this is a fantastic knife and great value for money. It really doesn't feel like a 'cheapo-pattern' blade but a legitimate lightweight choice. I would love to see this model available in a more 'up-market' blade steel and in some other non-translucent colours such as orange, green, tan etc. I'd certainly buy another one...or two...or three! Sorry if this review has been a bit of a behemoth to get through, but hopefully someone will find it useful! Here is one last beauty shot...
    Cheers for now,
    Uke.
    Jul 2003
    Nottingham
    Re: Spyderco Manix 2 Lightweight Review
    Stonkingly good review, thank you.
    I almost bought one when they hit HH but poverty stayed my hand, however after reading this the electricity bill can wait!
    Jun 2010
    Everberg (Belgium)
    Quote Originally Posted by Danzo View Post
    +1 : cheers for taking the time to make that review and for sharing it with us - double stonkingly good !!
    "Guns don't kill people - people kill people" ATB Antoine
    Sent from my PeeCee using MyMouse.
    Jul 2006
    Here and there
    Thanks for the review, Uke - just great.
    I didn't think I'd ever get interested in the Manix after selling one of the old black behemoths - this has now changed.
    May 2012
    Clitheroe
    great review mate enjoyed reading it now i want one lol
    lee
    Excellent review, many thanks.
    Apr 2012
    SW London
    Yea thanks a lot, trying to hold onto my hard earned money and this post really does not make it any easier-.-'
    oh and your shots look amazing, HH/spyderco should buy them of you.
    Paintings. Sculptures. 3D/CAD. Basic animation. Graphic design. Web design. Print design. Anything design.
    Jan 2012
    Brighton, UK
    Great review mate - I think the G10 version just still wins out aesthetically for me, but your pics have made me look at the Lightweight version with a lot more love than the stock photos give to the knife
    Nov 2011
    North West England
    Glad you're finding the review helpful chaps, many thanks for the kind words!
    Good call sir! I think you'll be very pleased with it Dan, especially as you like your FFG Orange sprint so much.
    Quote Originally Posted by andy1000 View Post
    I agree mate, I still find the G10 version more aesthetically pleasing, but for the price and weight this is well worth a dabble
    Apr 2006
    Excellent review, thanks for taking the time. I don't think the Manix 2 lightweight will join my M4 sprint simply because I never really have a problem with weight (of knives, anyway). In fact, I rather like the density of knives like the Manix 2 M4, Native 5 etc.
    It's good to know that the lightweight option is not too much of a compromise, though.
    Xav
    "I refuse to have a battle of wits with an unarmed man"
    There are 10 types of people: those who understand binary and those who don't.
    Oct 2010
    Suffolk, UK
    Fantastic review. Rep given.
    Certainly convinced me that I need one!
    It's all fun and games until someone gets hurt.
    Then it's a sport.
    Jun 2012
    Nice review, much appreciated.
