Results 1 to 14 of 14
    Jan 2003
    derbyshire
    First dagger blade
    I had wanted to make dagger or double edged blades for a long time but was put off because all the stuff I read about it said it was really difficult. As I plan to make some collectable folding daggers like Danzo likes, I though I better practice. So I took some EN42 4mm thick, cut it to size on the bandsaw and use the angle grinder to rough grind the bevels. Then the belt sander to do the bevels. It didn't take long, it is a bit rough but I'm quite pleased with the result. its 20mm wide and the blade is 100mm long
    Apr 2005
    N22.
    Re: First dagger blade
    That looks very good. Can't wait to see the finished blade.
    What shape/style are you going to do for a handle?
    Oct 2005
    Hull
    That looks good enough to me.
    Ive been thinking about it myself but have also been put off by other peoples comments.
    Is its as hard / harder / easier than people say
    glasgow
    nice straight line down the middle. nice.
    that would be too hard with the equipement i have.
    kent
    Really difficult?
    Looks good and I bet you made it look really easy.
    Bill
    Jul 2003
    Nottingham
    That's looking good Shing. Hopefully now that Sammis chicken pox is passed I'll be able to get over to see you to have a chat.
    Jan 2003
    derbyshire
    Hi Danzo, the dreaded chicken pox, I remember the twins having them last year.
    It was not as difficult as I tought but needed concentration and a light touch. Takes a bit longer to do than a single edged blade. I chose a blade profile that made it easier.
    Jul 2003
    Nottingham
    Quote Originally Posted by shing
    Tabitha has the chicken pox now and as she is so small she looks a bit like one large pustule!
    However as Sammi will be in nursery next week I should be free, assuming I can walk, which a gout attack is currently stopping me from doing.
    Blade does look very nice though, and it will be fun to talk through some handle designs as well.
    Derbyshire
    Nice work Shing!
    Jan 2003
    derbyshire
    Thanks David, I'll try to get some folder protos finished for you to see Dan.
    Aug 2005
    Le mans France
    Very good. It's really hard to make a perfect center ligne for the double edge, good work.
    @ + ben
    Nov 2003
    Near Rugby, UK
    Hi Shing,
    What's the other side like - is it the same (ground to two edges) or have you left it flat in a chisel grind?
    Cheers
    Stephen
    Consume alcohol sensibly - life is too short to drink bad wine
    Jan 2003
    derbyshire
    I have ground both sides, I think it makes a better blade although I have a folder design that uses a chisel ground blade because it has to fit into a handle just a fraction wider than the blade and sharp on both sides.
    The blade in the photos do have some imperfections as you would expect but I hope later blades will be a lot better.
    Lincolnshire UK
    Looks great.
    Going to be good to see the finished design.
    Mark
    Reviews Here (Mainly Torches at the moment + the odd knife now!)
    New Host www.cones-stuff.co.uk
  1. Collection of blade info...
    By Inspector71 in forum Resources...
    Last Post: 31-01-06, 04:57 AM
  2. Help with handles
    By JJH in forum Tips 'n Tricks...
    Last Post: 12-01-06, 08:25 PM
  3. Shocking Dagger Blade
    By ZDP-189 in forum Edged Tools Testing & Reviews...
    Last Post: 09-10-04, 08:34 PM
  4. Allan Blade Bushcrafter
    By Cool in forum Basecamp...
    Last Post: 16-08-04, 04:27 AM
  5. File Blade.. revisited!
    By Dave Barker in forum Handmade & Custom Knives - General Discussion...
    Last Post: 27-05-04, 12:30 PM
