Results 31 to 45 of 127
21-05-07, 05:34 AM #31
Re: Blade Grinding (My way) lot’s of Pic’s
Another option rather than having to adjust your table is to put a bolt threaded through the angle iron down toward the table. As you turn the bolt in and out it changes the angle of the angle iron in relation to the table and platen. Works very well. I didn't come up with the idea by the way but found it on a knife grinding video and copied it. Akraven
21-05-07, 12:07 PM #32
Any chance of seeing a pic of this, Akraven???
Please!
Russ aka mack1
"Once a Marine, Always a Marine!"
"The most terrifying words in the English Language are: "I'm from the Government, and I'm here to help.""
Ronald Reagan
21-05-07, 06:27 PM #33
I'll try to take one today and post it later. akraven
21-05-07, 10:07 PM #34
Thanks!
Russ aka mack1
Ronald Reagan
22-05-07, 01:28 PM #35
[QUOTE=Xunil;525929]Interesting way of doing it.
I freehand grind all my blades.
The moment you put a jig in front of me I go all to pieces.
QUOTE]
Xunil, more Power to ya!!! I couldn't "Freehand" to save my life!
You, sir, also have my admiration!!!
There's something we need here! A "go all to pieces" Smilie!!!Last edited by Mack1; 23-05-07 at 03:06 PM.
Russ aka mack1
Ronald Reagan
23-05-07, 05:29 AM #36
My apologies for taking so long to get the pic's posted. My FTP server that I upload with has been having problems (either that or I am having problems!) I will get them posted as soon as I can. akraven
23-05-07, 03:03 PM #37
No problem! At your convienience.
Russ aka mack1
Ronald Reagan
25-05-07, 12:23 AM #38
Well finally conquered all the problems and here are the pic's.
You clamp the blade onto the jig and by cranking the allen head bolt up and down set the angle you want. Then just grind first one side and then the other going through each grit. By picking one of the horizontal lines to align to and making a mark on the back of the blade to align to the set pins at the bottom you can keep your angles and create good grinds!
Hope that helps. If you have any questions just holler. AkravenLast edited by akraven; 25-05-07 at 12:25 AM. Reason: fixing pic's
25-05-07, 11:04 AM #39Junior Member
- Aug 2006
- Atlanta,ga.
- 20
- 0
IS THERE A CHANCE YOU COULD SHOW A COUPLE OF PICS WITH IT AT THE GRINDER.i LIKE THE SIMPLICITY AND IT MY HELP WITH MY SHAKIN IN MY RIGHT ARM AND HAND.GEORGE
25-05-07, 02:55 PM #40
akraven, does having a single bolt, in the middle, give it a tendency to rock at all?
Thanks for getting the pics up, too!!! I didn't swing by here yesterday.
You may have just saved me a considerable amount of work. "Though I already have the pieces/parts to do it Aly's way. Then again, maybe I could try both ways.
George, please don't "Shout"(all Caps).
Or was "Caps Lock" on?
Russ aka mack1
Ronald Reagan
25-05-07, 07:40 PM #41Junior Member
- Aug 2006
- Atlanta,ga.
- 20
- 0
sorry caps were on I'm not the best with there things yet
25-05-07, 09:42 PM #42
That's OK, George. I'm not the most "Computer Literate" person in the world, either!
Russ aka mack1
Ronald Reagan
25-05-07, 09:46 PM #43
Russ aka mack1
Ronald Reagan
26-05-07, 09:40 PM #44
I will work on some more pic's today. The single bolt doesn't seem to create a major issue with rocking. When you see a pic of how I hold it it should be a little clearer. akraven
27-05-07, 12:26 AM #45
Here are a couple more pic's that may clear this up.
As you can see you can stabilze the jig quite easily with your hands. The platen on my grinder is set @ 90 degrees and all adjustments are done with the bolt. Hope this helps. By the way my apoligies to the original poster for stealing this thread. akraven
