There should be a few threads on this![]()
Firstly you will need the following items.
1.PP9 9 volt battery.
2.Battery connector.
3.2 Crocodile clips.
4.Cotton buds
5.Table salt
6.Water
7.Plastic bottle top.
8.Nail varnish
9.Needle
Method.
1.Clean metal surface, degrease, and leave to dry
2.Put a thin coat of nail varnish onto the metal surface and let it dry.
3.Place some salt and water into the plastic lid.
4.Connect the Positive (Red) battery lead to the metal with the crocodile clip.
5.Connect the Negative (Black) lead to the cotton bud with the crocodile clip.
6.Gently scratch the pattern onto the metal surface using a needle.
7.Dip the cotton bud into the salt water, then gently wipe the scratched surface with the wet cotton bud.
Note: The crocodile clip on the cotton bud must touch the wet bud. The cotton bud will start to go black as metal is removed. Stop every now and then and remove the blackened salt water so that you can see what you are doing.
Try it out on a piece of scrap first, it's really quite effective.![]()
regards
beach bum
nice job, innit good when something works.
