Results 1 to 14 of 14
    Apr 2007
    Sussex
    First project......
    I'm about to embark on putting scales on to a full tang blade for the first time and had a couple of questions, if anyone would be so kind to help out......!
    1. Drilling for loveless bolts - is a step drill bit essential/desirable or not really needed?
    2. Attaching vulcanised fibre liners - I've read epoxy resin is used most often; is it best to glue the liner to the scale first and then to the tang, or to the tang first?
    No doubt there will be more questions once I've started - thanks to any with answers!
    香港 H.K
    Re: First project......
    Hullo, that looks like me!
    1. The bit helps, but with a bit of artifice, a twist drill plus an end mill will do.
    2. I do both together.
    "Small, fat bear" All images and text . All rights reserved. ZDP-189 on Slingshotforum.com
    香港 H.K
    2. One side then the other, though.
    Aug 2007
    Cornwall
    I've just tried putting the liner on the wood, then when its dry I plan attaching the thing to the tang .... if this turns out to be more trouble than its worth , I'll let you know.
    The best advice i can give, is to get some cheap wood, and old unused knife(i used an old kitchen knife)and have a go with that. then once you feel brave ( with a couple of beers inside you ) have a bash with a decent blade .... good luck anyway
    Aug 2007
    Cornwall
    better not have the beers though
    Jan 2006
    North East UK
    I always put the liners and scales on at the same time.
    Providedyou prepare everything properly and have your placement holes drilled just right I see now reason to glue liner to scale, clamp, dry and sand only to repeat the entire process a second time.
    The whole point to Loveless and similar fasteners is that they provide a mechanical joint fixing the scale to the tang. As such, if your fit it good to begin with, you can mask off the blade then slip the liners on with a think coating of glue then the scales and tighten the Loveless bolts down.
    That said, a lot of people get good results doing the liner/scale/glue/clamp/dry/sand then fit to tang process, so I guess whatever you feel most comfortable with.
    May 2006
    Funkytown
    glue liner to one handle slab, drill and prepare for gluing, glue. Glue other liner to other side, glue to tang, drill through the holes drilled on the other side, bolt and ifnish. This guarantees the holes line uo
    epoxy is , imho essential, other glue is just not up to it
    Apr 2007
    Sussex
    I liked the bear - what can I say?
    Thanks for the tips so far - do any of the tutorials (links on other threads) show the process particularly well?
    Sep 2007
    northants
    Bond them all on at the same time, 24 hour epoxy has about 4 or 6 workable hours so its not going to set for ages . Take your time make sure everything fits without epoxy first,then lay it all out on newspaper or what have you and proceed NOTE Wear gloves (surgical) there the best should olnly take 10 maybe 20 mins max good luck
    May 2006
    Funkytown
    Apr 2007
    Sussex
    Cracking - many thanks
    Glue liners to both scales.
    Drill holes in one scale, using pins to make sure everything stays lined up when drilling further holes.
    Repeat for other scale.
    Shape and finish bolster of both scales while the scales are held together with pins pushed through to make sure the bolsters are symmetrical - knife isn't present at this time.
    Glue scales to knife blade.
    Apr 2007
    Sussex
    Thanks guys - I'll post pics once it's finished (if it's not an abject failure!!!!!)
    Dec 2006
    URUGUAY
    I see you got all the advise ,so I can now wish you luck!!You will do a fine job for sure!!
    Albert
