Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Jul 2007
    Alabama
    Re: first knife supplies what kinda scrap should i use?
    The problem with rebar is there is no consistency to the quality of the steel. Just because you managed to make a decent knife out of one piece does not mean the next piece you try will even harden. Rebar is held to some of the lowest tolerances in the steel industry. I understand that some of the larger files and rasps are case hardened, but most are simply high-carbon steel (.9%+), and therefore can be made into good knives. Springs can be made from any number of different steel grades, but any steel that will make a decent spring will also make a decent knife. Just watch for damage from it's previous life as a spring coming back to haunt you, as it may have become scrap for a reason.
    Basically, any tool that requires a durable edge can be re-made into a servicable knife. Finding the best heat-treatment, now, that can take quite a bit of experimentation.
  2. #17
    Dec 2007
    basically atlanta
    hey i was wondering....
    would bolts work at all?
    like i said my dad tears apart old trucks so he's got quite a few big ol' bolts layin around.
    would these be high carbon or low or pearlite or martensite or what?
    thanks so much for the info guys.
    -jared Z
    serge panchenko,PSY,dave budd,belabear,benchmade owner.
    Jziegenbein on Dfogg
    "please, pass the salt" ~ probably Ghandi
  3. #18
    Feb 2006
    Ephrata,WA, USA
    Besides leaf springs, I have hi speed roller chain,(5160) harvester chain from large hydraulic chain saws for clearing brush along road ways(L-6 or 15N 20). Chainsaw chains and chain saw bars are fairly good L-6 or 15N-20. I have old cable that has fair Carbon determined from a test quench. Wrist pins and ball bearings are a good source of 52100. Drill steel is probably S-7. Most of the 15N-20 in the neighborhood is from recycled timber band saw blades. Steering linkage and rock shafts from tractors is probably 5160. Bailer forks and tines are probably 1084-1095. When in doubt do a test forge and quench then check with a file or break the material. Many planer blades are D-2. A Rockwell test would be good.
    I've made simple knives that I have given to supervisors or owners of different buisnesses. This gives me access to almost unlimited supplies. This also helps find new friends...Take Care...Ed
  4. #19
    Jun 2005
    South London
    Quote Originally Posted by lilzee View Post
    ...snip...will the rust really matter?...snip...
    I shouldn't think a bit of surface rust would be a problem, you'll be getting scale anyway.
    One thing you definately want to stay clear of is galvanised metal. Heavy metal fever is a killer.
    Have fun
    DS
    After one melee, William Marshal went missing, delaying the presentation of his prize as best fighter. They eventually found him in the blacksmith's with his head on the anvil as his helmet was beaten back into shape so he could take off his armour.
