Results 1 to 15 of 16
    Oct 2003
    Birmingham
    How do I get corroded batteries out of a Maglite?
    The good news was that I found a brand new mag 3c misplaced a few years ago.
    I suspected a problem when it took mole grips and wrench to get the cap off (wrecking the knurling and finish ) and then found the grey powdery stuff.
    So how can I get the batteries out? They are in solid
    cheers
    Jul 2007
    Re: How do I get corroded batteries out of a Maglite?
    Vinegar will eat away at the corrosion thus freeing them.
    The other option is to take the head off, take the switch out and hit them out.
    Nov 2007
    Cape Town SA
    Id go the vinegar route first, violence can also cause you to break your finger off in your watsit...
    Hénré
    Guycep owner
    "Thinking is the hardest work there is, which is probably why so few engage in it"
    - Henry Ford -
    Dec 2002
    Boringville, England
    A mechanical advantage tool, e.g.:
    Drill the battery, insert corkscrew, use leverage against tube of the Maglite.
    I've never tried this, but it might work.
    mirage
    "The wise man speaks because he has something to say; the fool because he has to say something."
    Plato
    "The more corrupt the state, the more numerous the laws."
    Tacitus
    Aberdeen
    'Tube' the light, like Mad1 suggests.
    Or throw it away because the switch and reflector are probably knackered now, anyway.
    Don't the UK importers have a marvelous returns policy? I can't remember their name but I do remember some amazing tales.
    If work was a good thing, the rich would have it all and not let you do it.
    Elmore Leonard
    I sew custom nylon stuff, have a look at this thread Or at the Facebook page.
    Oct 2003
    Bournemouth
    I think the warranty good as it is doesn't cover battery leaks.
    Get a new one.
    We shall not cease from exploration.
    Nottingham
    Burton McCall are indeed very helpful and have willreplace worn out parts but the warrenty does not extend to damage causedby batteries.
    To take the head off you make need a silly imperial allen key though (screw located under the rubber switch bit)
    WARNING contents of this post may not be consistant with reality
    Please copy and paste the following to taste !,'.()"";:?
    Aug 2005
    Bucks
    Not sure if this applies to UK folk, but I've heard of those in the US being able to claim for a replacement light from the battery manufacturer. Probably only applies to the big name battery companies such as Duracell though. Might be worth a shot.
    If not then the vinegar/brute force methods are pretty reliable
    Regards,
    Tempest
    Surrey
    Kind a job WD40 was born for. Yes vinegar will eat the corrosion, but so will the solvent in WD40.
    leave it soaked in WD40 for a day or so
    or you could try a cocktail of vinegar and WD40 .. but don't forget the little umbrella
    I had a similar problem with the AAA version, managed to tap the battery out in the end but even with soaking/cleaning the the inside,spring and cap it was never the same. I bought a new one in the end.
    Nov 2003
    guernsey
    hot soapy water worked for me the end spring was a write off though
    i never did get the replacement from burton mcall had to get one from local
    retail supplyer
    lincolnshire
    Fill it with WD40 and leave to soak for about a week, shoud'nt be a problem as you lost it for years!, then clean out all signs of the battery leak, and return it to the importers, if you get no joy, insist it is returned to you, and send it to mag light.
    this worked for me, a few years ago.
    Oct 2003
    Birmingham
    Thanks for the advice.
    I did initially try WD, but it seems to have evaporated and not loosened them. I did not immerse it though, just a good spray.
    I could not see any allen screw under the rubber switch, but from the bulb end, there are two indentations in a brass ring which look like they are designed for something like the points of circlip pliers. Does anyone now if this ring does hold the switch assembly in place - if so, I'd probably have to make something to unscrew it.
    TBH, it's just so annoying that I've found it again as it is now going to bug me until its all nice and clean and working again
    Dec 2002
    I don't know if this series of photographs might help?
    mirage
    Plato
    Tacitus
    Apr 2008
    Greece
    The vinegar solution worked in my case. I used warm water (actually I used a pot and under steady but relatively low temperature) with a lot of vinegar. I left for a couple of hours. I don't know about the WD40 thing but the vinegar sure works. You should give it a try.
    People should not be afraid of their governments. Governments should be afraid of their people.
