Page 1 of 15 1234511 ... LastLast
Results 1 to 15 of 219
    Jul 2008
    Norfolk
    Work in progress - If I remember. . . .
    After a couple of requests , I've decided to do a work in progress thread. I'm afraid the idea came about just after I'd cut out my blanks and annealed them, but hey! not to worry.
    The first picture is rather disturbing, and if you are of a nervous disposition, or have any small children in the room, turn the computer off now.
    Yes, its me, and yes, I do look like an escaped psychopath. I just thought I'd show myself, rather than make it a faceless thread. Sorry
    Next up is a picture of my steel of choice - CPMS30VATS34AUS8ZDP149440Chighcarbonhighchromiumhi ghmolybdenumhighvanadium154CM Commonly known to the layman as a rusty old saw blade.
    Next up is the pits being ground out, profiles ground, and holes drilled.
    This is the two after being ground flat, ready for the tang tapering.
    Now time to grind a nice hollow ready for flattening and tapering the tangs.
    Jul 2008
    Norfolk
    Re: Work in progress - If I remember. . . .
    Hello again! Bored yet? If so just say and I'll stop!
    Heres the tangs after being nicely flattened and tapered
    View of taper from bottom
    And yes - you guessed right, the view from the top!
    Thats all for tonight, as its now ten past two in the morning, I've got to be up at six, and as you can see, I really could do with some beauty sleep
    Hopefully I'll remember to take some more pics as I progress. However don't be surprised if this suddenly jumps to making the sheath......
    Thanks for looking
    Ian
    Feb 2007
    Northern Ireland
    Great work!
    The transformation from the rough shaping of the rusty saw blade to shiney new knife blade is really cool.
    Looking forward to seeing the rest!
    Jun 2008
    Southern US
    Can't wait to see the knives finished. I have a blade like yours.Here's
    a photo of it ...I think it's 28 inches..
    Frank
    New Zealand
    1
    L6 steel is the most likely source for both those blades...we hope...
    Howard Clark will tell what a great steel it is...
    New Zealand
    1
    and...the Loveless influence is in these creations, and I am eager to see the result, Mr Bailey...
    Jul 2007
    Alabama
    I have a piece of CPMS30VATS34AUS8ZDP149440Chighcarbonhighchromiumhi ghmolybdenumhighvanadium154CM that looks eerily similar, in fact I had to check to see if it was still there.... I don't know what mine is either, other than good steel based on the simple tests I've done on it. Very nice takes on the Loveless style, will the big one be double-ground?
    Jul 2008
    Norfolk
    Glad to hear I'm not the only one using such high tech steel
    The biggest of the two will be an elongated (6 1/2") chute knife, but with a full flat grind rather than a sabre grind, as I'm not good enough to do a "proper" chute grind I've tried, but I always seem to get a wavy grindline. I've also tryed using a jig. But found it just annoyed me even more. Hence I do what I can free hand.
    The drop point will have a full 10" hollow grind.
    Knowing my luck, this thread will come to an abrupt halt halfway through. I'm bound to ruin something now I've started this
    Thanks for looking
    Ian
    Dec 2008
    Camberley, Surrey
    Cool, thanks for the pics. Now your not just another faceless BB Monster. How do you heat treat the saw blade stock?
    Whoever dies with the most tools wins.......Now accepting donations.
    I buy old folding and fixed blade knives of all kinds. Especially Case. PM Me.
    Jul 2008
    Norfolk
    Quote Originally Posted by Iron Hoarder View Post
    Now I'm probably THE BB monster I've just noticed how wonky my eyes are Still, thats Norfolk breeding for you. . . . . .
    Heat treat is as follows - Once the I'm ready, I normalise, and get my stamp done before it cools too much. Its then heated to non-magnetic, and edge quenched in my super death mix. This is waste oil I acquired from a garage I was working at. I'm pretty sure that as well as used engine oil, it contains anti-freeze, brake fluid and screen wash. The birds drop out of the trees when I quench, but it does do a very good job!
    After this I temper twice at 220c for one hour. This seems to give a very good balanced edge. The smaller 4mm German blades I use only get a single temper, as this seems to work well. I guess different blades, different compositions. The steel on this one by the way is 7/32" thick. This ends up at 3/16" by the time its had the pits removed.
    Ian
    Jun 2008
    North Hampshire
    Quote Originally Posted by irbailey View Post
    G
    Thanks for looking
    Ian
    We'll only make you start again Love seeing your work when it's done and it's fascinating to see the process.
    Hope all goes well and thanks for showing
    John
    Now I'm old and getting grey
    Way down in Florida
    I can only manage one a day
    And we'll roll the woodpile down
    Dec 2008
    Camberley, Surrey
    Thanks! I think you could call that poor man's super quench.
    Jan 2007
    kent
    Good stuff.
    ...No slacking now.
    3 hours sleep should be fine for operating heavy machinery and knifemaking
    Ruin is the Devil's work, consecutive and slow
    Fail in a moment no man did
    - Gwyneth Jones
    Feb 2006
    Swansea
    great thread Ian,
    Jul 2008
    Norfolk
    Thanks Chaps (and chapesses - its hard to tell).
    Well, heres tonights instalment. So far so good. (I need a "Wiping sweat from brow" smilie)
    First up, was marking the grind lines on the edge.
    The grinder rest was then set at about 45 degrees ready to grind the lead- in bevels. Before anyone asks, the grinder is one of BB Aly's minigrinders. And what a super piece of kit it is too . 3-speed provided by simple pulleys, 1.5 hp motor, and exceptionally well made. Plus he is a good bloke to deal with.
    I can now do in 1/2 hour what it used to take 2 nights to do.
    Heres a shot of the pair after the lead-in bevels were ground
