During the past year I've had several emails and PM's asking how I make my sheaths. I have promised several people that I would try to make some kind of tutorial. A thing, I found out, is a lot easier said than done. Lots of times I have started taking pics, and then forgotten to follow up all the way through each sheath I made. Now finally I think I've done it - well almost that is....
The following pics show how I make sheaths for a customised Fällkniven WM1, but the process will be similar for other knife models too.
When one of my knives is ready for making a sheath, I always start by measuring and drawing the shape on paper to make a pattern. I start with drawing a centreline. The back or spine of the knife is placed on this line and then rolled to the left and right to draw the profile. It is important that you do this carefully so that the knife does not slip. Holding the knife with my left hand, I draw the outline of the knife's profile with a pencil in my right hand. When I've done this from both sides of the knife, I remove the knife and draw the outline of the sheath. I usually draw the sheath outline about an inch away from the knife's outline to make sure the sheath will fit the knife when stitched up. Note: different thicknesses of leather will require different size patterns, so will different size / thicknesses of handles. If you make a pattern for a specific knife model, you must make sure that you make all handles more or less exactly the same size.
After you have drawn the outline of the sheath along the edge and handle, you have to decide how far up the handle you want the sheath to fit. This is more or less an eyeball affair, but you may take the design and handle proportions into consideration. A general rule says something like the sheath must go 2/3 up the handle or something like that. Also make provision for the belt loop. The pic of the pattern show the drawing for a left handed sheath seen from the flesh side of the leather (to make a right handed one the belt loop should be placed to the left hand side when seen from the flesh side of the leather - just flip the pattern over to use for right or left handed sheaths).
The outline of the knife's edge and handle is also drawn to make the welt piece sandwiched between the actual sheath piece of leather.
Once the pattern is done I transfer it from the sketch paper onto some more rigid paper or hard plastic, and use that for future sheaths. The pattern is then transferred to the piece of leather you are going to use for the sheath. I usually use 3,5 mm hick leather, but may sometimes use other thicknesses too. To be able to form the sheath to an exact fit to the knife it is important that you use vegetable tanned leather. Chrome tanned leather can't be shaped in the same way, and therefore do not work for this process.
Once the pattern of the sheath and welt has been drawn I cut it out with an ordinary Stanley knife or a scalpel. I wrap it around the knife to make sure that it will fit properly.
I usually glue additional pieces of leather on the welt in the handle area, in order to make the welt slightly wedge shaped - thicker in the handle area than in the blade area.
Don't try to understand 'em, just rope, roll and brand 'em...
