Results 1 to 11 of 11
    Wiltshire
    Advice needed re sticking a handle on a Bushie blade
    Hi all,
    I have spent the morning shaping and sanding a set of canvas micarta scales to go on my bushie project after I split a black palm scale last week.
    I am using black fibre liners and wanted to know: should I glue them to the scales, then once dry, glue the whole lot together; or just go for it, and glue handles, liners and blade all in one go?
    Hopefully I won't make too much of a screw up this time round.
    Stretch3144
    Ars Lenit Iter - Skill Smoothes The Journey
    EDC: Khoi Bullfrog & MacsCustom XM-L EDC
    Aug 2008
    Doncaster
    Re: Advice needed re sticking a handle on a Bushie blade
    Just glue the lot together in one go.
    Scotland
    I always cut the liners a bit bigger than the scales an glue them together first, but thats not say thats the right way!
    Mar 2008
    sheffield uk
    i glue the liners to the scales first then let them dry before sticking to blade, i dont think there is a "right" or "wrong" way just which works best for you
    Mar 2007
    Kent
    I always glue up all at one time, like making a multi-layer sandwich, then clamp it all up together - means all the layers get the same clamping pressure, and hopefully the same glue layer thickness.
    Peter
    The law hangs the man, and flogs the woman, that steal the goose from off the common
    But lets the greater villain loose, that steals the common from under the goose. (anon, 18th C)
    Stuff I have made...
    Mar 2004
    Birmingham
    I tend to glue the liners on fairly early on and then treat the whole thing as a single block. In fact I usually glue the scales on while they are a little oversized and then sand down to meet the tang. The main reason for this is so that you can get the front face of the scales (where the guard would be) finished to how you want it before you glue the scales on, because its extremely difficult to work on afterward.
    I also like to drill a few blind holes through the liners into the scales before gluing to give a bit more of a key to the join, but to be honest I doubt this actually makes a lot of difference.
    Aug 2003
    Kent England
    Quote Originally Posted by narsil View Post
    I think it does make a difference, gives a little more area for the epoxy to grip.
    Barry
    Guycep Owner
    Jul 2009
    Essex
    I glue the lot on together. See my post on how I made a "Bbno & crockett" knife. There are some pics of how I did it and it worked out great.
    Apr 2007
    Rhondda Valleys
    I like to glue the liners to the scales first
    Just because you can get a more accurate / better finish on the front of the scales nearest the blade.
    If the liners and scales are slightly out once glued it would be a nightmare to try and re-finish this area.
    Just my opinion
    Scotland
    Quote Originally Posted by Rob J Evs View Post
    Just my opinion
    Yes thats why I do it makes sense now
    Jul 2009
    Essex
    I finish the fronts of the scales, drilled the spacers to match the scales. Put a scale and a spacer together with the pins. Sand the front of the spacer to a good fit, then slightly enlarge the holes in the spacers. When you come to clamp it all up because the spacer holes are a loose fit you can slide the spacer about to get a perfect match at the front. then clamp tight.
