Results 1 to 3 of 3
Thread: A technical question
04-09-09, 11:09 AM #1
Not sure is this is the best forum but:
I saw a knife with the following specs 1/4'' pitch scalloped edge; what does pitch means, is it the distance between two ends of each scallop (whre it is pointy)?
Many thanksMy knife-torch-watch combo: UKPK - 6P - no watch!
04-09-09, 07:18 PM #2VIP Member
- Feb 2009
- Lancashire
- 51
- 836
- 6
Re: A technical question
Probably. It's a term more commonly used for screw threads, but it seems to have the same sort of meaning here; the peak-to-peak (or trough-to-trough) dimension of the serrations will be 1/4".
If it was a saw, we'd say it was 4 Teeth Per Inch.
Tim
07-09-09, 03:20 PM #3
Thanks a lot, sounds consistent with what i found on a mechanical engineering website. If you wonder why, it was about specs for industrial bread-slicing machine blades!
