Results 1 to 11 of 11
    Feb 2004
    Buckinghamshire
    Double quenching
    I have noticed some very nice hamons or quench lines on blades that have been multiple quenched. Could this be done with clay backing? I.e. to heat and quench in the Japanese style then wait until it cool and repeat.
    What would be the effect?
    Would there be any difference if you used different quenchants with different cooling rates?
    thanks in advance
    Beautiful things don't ask for attention.
    http://farquharforge.com
    Cornwall
    Re: Double quenching
    Quote Originally Posted by Lord Farquhar
    thanks in advance
    My thoughts......
    Its likely that the clay would only stay on for one quench before begining to disintegrate and fall off.......
    Different quenchants?......dont know. But a water quench seems to be preferred for Japanese style because its a fast quench and gives a better hamon than one done in a slower quench like oil.........but if your using water, then expect failures (blade cracks).
    As with everything..there comes a time when you have to experiment yourself...... see what happens......and learn
    ...formerley known as "coutel".
    Cornwall
    Forgot to say that on some of my first knives..I could get as many as three hamon lines laying on top of each other in just one quench....looked like tiger stripes.
    Tai Goo was also developing a quench in a vibrating tank which gave wavy lines and rainbow colors.
    Feb 2004
    Buckinghamshire
    I tend to use refactory clay and its a bugger to get off as its quite stuck on after the first quench. Also it (the clay) could theoreticaly be replaced as it does leave tell tale marks of where bare steel was and where clay was.
    I suppose i just have to give it a bash.
    Cornwall
    Great...Give it a go and tell us the results.
    My clay begins to break down after one quench..
    Cornwall
    As the clay suggests where the hamon is going to be, and the thickness of the spread will also decide the pattern...............so doing multiple quenches with the same clay,what are you expecting to happen?
    Feb 2004
    Buckinghamshire
    Not many things in life are as good as narking you off, than spending hours anealing and griding and shaping then backing in clay then cracking the steel in water.
    As soon as it happens its tools down and back home. I hate it when it happens.
    Feb 2004
    Buckinghamshire
    Quote Originally Posted by coutel
    a more pronounced hamon was the idea. or move the clay and get one hamon over the other?
    Ie do one quench with the clay high then remove the clay or just add some more so the line is lower so you get a double hamon....
    this is getting complicated
    Cornwall
    Unfortunately..thats life ...got to take the rough with the smooth.
    Cornwall
    You cant get much more pronounced than Don Foggs hamons...or look closer to home and see Jon Barons.......Quenching is one thing....the skill is the right technique to bring it out and show it .......
    The scrub-steppe...
    With water quenching, timing is everything. If you're not cracking blades, you aren't making and quenching very many.
    Try steels that are low in hardenability. By this I mean give serious thought to abandoning any alloy that contains significant amounts of manganese. This is the one element that interferes with hamon development because it's in the steel in the quantity it is to make it foolproof to heat treat by somebody working for minimum wage. Not that it can't be done with 1084, but what a learning curve.
    Try mixing some simple clay in the refractory to thin out the mix some. It's easier to get off the blade afterward.
    Some time ago there was a discussion about "double hamon" on one of the nihonto lists. You can have multiple lines on a blade from section thickness alone as the mixed material shows bands that contain differing ratios of pure martensite through pure pearlite/ferrite etc. Multiple bands are not the result of multiple dips in whatever quenchant. Once the blade is below the nose of the TTT curve, whatever shades are in the blade is there for keeps. If you reclay and reheat, it all goes into solution again and you'll get a new hamon. Some sword aficionados believe that you can see a phase change in a sword that has been rehardened, I'm not so sure. But, a lot of nihonto were piled up and burned after the war and I'm sure that enterprising souls obtained the wreckage and tried to reheattreat them.
    I personally do not believe this has anything to do with Mystery or Magic or the Full Moon or vibrations whether inside or outside the hand of the maker. Your practice may vary. I routinely get multiple bands of hamon on most of the blades I do, seven, maybe eight on the last homemade steel (kodai) I did. I'll have to get a pic up.
    If you want to try two different quenchants...and are feeling gutsy...have a tank of cool water and a tank of your favorite oil close together. Just a second or second and a half in the water to set the edge and then into the oil to finish the cool down. Nice hamon, no clay. The line tends to be straightish but it will stand out on a polished blade and achieves somewhat the same effect without having to mess with mud. Remember timing is everything, you're going to crack some learning this one.
    I'd rather just get one or two really bitchin lines like Don does but my stuff is not like his. Make more blades.
    Once in a while you can get shown the light, in the strangest of places, if you look at it right...
