BritishBlades.com
BritishBlades Website BritishBlades Forums BritishBlades Gallery BritishBlades.com
Welcome to the BritishBlades forums.
You are currently viewing our boards as a guest which gives you limited access. By joining our free community you will be able to post your own topics, respond to others topics, communicate privately with other members (PM), respond to polls, view the gallery and access many other special features. Registration is fast, simple and absolutely free, the water is warm and the natives are friendly, so please, join our community today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   British Blades :: Custom Knife Making > Custom Cutlery Forums > Tips 'n Tricks... > Tutorials Archive...
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 14-08-04, 06:35 PM
ZDP-189's Avatar
ZDP-189 ZDP-189 is offline
BritishBlades Moderator
Lightbulb Easy Scandi Tutorial
I was spouting off earlier to tenbears10 about how easy and quick it was to put together a scandi using my simplified assembly method. Well, to prove it's workable and as illustration, I made a scandi from a Brusletto blade (EUR4), a piece of reindeer antler (EUR1.7) and block of african blackwood (EUR10). All parts were kindly supplied by DennisH of Brisa.
Small, fat bear
Reply With Quote Top
Old 14-08-04, 06:36 PM
ZDP-189's Avatar
Re: Easy Scandi Tutorial
Instructions:
  1. Plan to make the bolster out of horn and the shaft out of birch or other softwood, separated by a spacer;
  2. Scribe a straight line across the blade shoulder and tang and carefully file the shoulder square to the line;
  3. Sand the bolster back and shaft front perfectly flat on a piece of 320-ish sandpaper stuck to a glass or other flat table;
  4. Mark off the position of the knife and tang on the side and top of the assembled, but as-yet-unglued, handle block;
  5. Over-bore the tang hole in the shaft so that the tang just fits in the round hole;
  6. Carefully slot the bolster as above but, because it's only an inch thick you can easily use a square needle file (specially buy a coarse and a fine one with a good handle) and/or 3 jnr. hacksaw blades taped or soldered together;
  7. Don't bother to inset the shoulder (or if you do, it'll be a lot easier having squared it);
  8. Slide the bolster on the tang as a guide and glue the shaft to the back of the spacer, then remove the blade;
  9. Preheat the oven to 50~70 Celcius;
  10. Pour slow set (1 hr minimum!) epoxy in the handle shaft. I like to use a syringe and needle and fill from as close to the bottom as possible;
  11. Insert the tang into the handle assembly, knife should point upwards;
  12. Excess epoxy should ooze out, roughly wipe the blade and then handle;
  13. Place tip up in oven over a tinfoil sheet. Allow glue to set in oven for 20min then allow to cool;
  14. Use sander (or file) to remove a little excess wood, bolster and spacer;
  15. With a coping saw, cut the outline, leaving some spare;
  16. With a hand file finish the shape;
  17. Sand and sand and sand till you have a perfectly smooth finish;
  18. Buff on a rag wheel with buffing compound.
Small, fat bear
Old 14-08-04, 06:39 PM
ZDP-189's Avatar
Here is my design process:
Small, fat bear
Old 14-08-04, 06:46 PM
ZDP-189's Avatar
The production process:
All seems to fit. I'll have to trim the tang though.
Note I decided to swap the moose horn with a piece or reindeer horn, becaus eit was smaller and had a smaller pith area.
Tang trimmed and back of the blade ground to shape. Note the slant.
Make sure you wrap the blade to protect you from the edge and point and to protect the finish from your tools and clamp.
I had to use the old drill stand because the drill press doesn't have enough travel.
Ugh. I messed up the alignment. It's OK, all I have to do is reposition the stuck on picture.
I grind the handle shaft face and back of the bolster perfectly flat on the sander. I follow up with sanding on wet-or-dry paper stock to a flat surface. This step is essential to get a good fit between the bolster and handle.
I slotted the bolster by drilling 4 undersized holes in a precise line, then chiseling out the sides using a needle file with a sharpened end, then two wood jigsaw blades side-by-side, then a proper wood-detailing chisel, then the side of a needle file. I got a tight fit with no gaps around the blade or between the back of the blade and the front of the bolster.
Here I trimmed the excess wood. Note the proper wood-type blade and good rigid hacksaw. This is much faster than a coping saw. Also note I left the base flat so the knife can stand unsupported.
Having test-fit the bolster and shaft, scribe/draw a line on the bolster and align with the wood block. Matching the centerline of the drill is essential. The bolster and wood must fit precisely. Do you notice that the sides of the antler have been ground off? Try clamping a round antler!
There's a trick here. Because shaft hole is overbored and the tang is a little loose, I stuffed a pea-sized ball of milliput (epoxy putty) down the end of the hole to hold the tang exactly in position while the epoxy cured. This ensures the alignment remains perfect. I over-filled the assembly with Pioneer Durasteel epoxy. It's expensive but viscous and bonds well. To ensure a good watertight fit I smeared epoxy on the back of the blade, on the tang, slid on the bolster, smeared epoxy on the back of the bolster and on the tang again. The whole thing was slightly over-filled and was assembled with force. I clamped the blade tip-down in the vice and used a rubber hammer to force the assembly together tightly. The force-fit is partly to do with the epoxy putty.
Here it is in the oven. The temperature is cool enough to handle without gloves. If it's too hot, you can damage the epoxy.
After 10 mins, when the epoxy is rubbery, I scrape the excess off the blade joint, taking care not to accidentally take too much out of the blade-bolster gap. I have to be very careful, because I'm using a hardened steel chisel point. I should really have a brass, bone or plastic knife.
I stuck the assembly back in the oven and after about another 15 mins, it was done.
Total production time up to this point was under 2 hours. The design work took another hour and a half.
File carving and finishing and buffing took another 4 hours. (Actually more, because I had to fill small a natural knot in the wood.)
Small, fat bear
Old 14-08-04, 06:55 PM
ZDP-189's Avatar
This is how it should turn out
I have followed the lines as per the design. Note the fish's body shape.
Symmetrical shape for ambidextrous use and for visual balance.
The handle is narrower before the end. This is to fit the meaty bits of the hand.
The flaring makes for a secure grip when drawn. I didn't put a lanyard on because the knife handle had to be small (OAL18.5cm) to balance the blade and there's no part of the handle protruding far enough to string a lanyard through. Any outdoor knife should really have one.
See the pores of the antler marrow? I had to seal those with superglue to prevent water getting in.
Small, fat bear
ggfh666's Avatar
ggfh666 ggfh666 is offline
Lost hair, kept powers
Talking Re: Easy Scandi Tutorial
Have you got pics of the steps you describe above?
It is that I don't understand it all, for example :
What do you mean with this? Do I file a 90° angle on the blade?
Sorry if this seems a stupid question, it's just a lack of experience....
Oops just too late...
ggfh666
Website of GGFH666
Support local guides in Kenya
JNeilson, KBA, Guycep, Narsil, Anso, Deviant11 and various blades owner ;)
Old 14-08-04, 07:23 PM
ggfh666's Avatar
Another question: how to get a good fit, no gaps, in the antler part of the handle?
ggfh666
Website of GGFH666
Old 14-08-04, 07:26 PM
rapidboy's Avatar
rapidboy rapidboy is offline
BritishBlades Administrator
Nice work on the knife and the tutorial.
Now quit messing around and get the sheath done
RB
Leather
Kydex
  #9
Old 14-08-04, 07:29 PM
JohanB's Avatar
JohanB JohanB is offline
Send a message via MSN to JohanB
Nice one. Ive used several of those blades. When i made my first knife i made a knife with such a blade, i was 6 years old then. Keeps a nice edge!
ZDP-189's Avatar
ggfh666, I'm typing as fast as I can!!! But keep on asking questions. I'll answer any I can.
Scribing on the blade: In this case, the bolster is designed to be slanted, so I had to scribe at an angle, so that the blade matched the slant of the bolster.
I hope I have answered your question about fit and finish with my annotation.
Small, fat bear
Old 14-08-04, 07:32 PM
ZDP-189's Avatar
RB
RB, to be honest I've never done a scandi sheath and I'm too tired to do one. I've invited a friend to collaborate on the sheath, but failing that I'll find another collaborator or (horror) try it myself.
There are excellent sheath tutorials out there and I wouldn't pretend to be even 10% competent to write such a thing.
Small, fat bear
Old 14-08-04, 07:40 PM
ggfh666's Avatar
Now it's up to me to try and bring this into practice.
Thanks a lot for this great tutorial.
O, and the knife looks great as well.
ggfh666
Website of GGFH666
Old 14-08-04, 07:45 PM
ggfh666's Avatar
One more question: how do you keep the front of the bolster clean with al the epoxy?
ggfh666
Website of GGFH666
Old 14-08-04, 07:48 PM
ZDP-189's Avatar
There's a picture of me scraping it off while it's still in a putty-like state.
Small, fat bear
Old 14-08-04, 07:52 PM
ggfh666's Avatar
So it is not only scraping from the blade but also scraping off the bolster.
Thanks.
ggfh666
Website of GGFH666
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Subscribe to BritishBladesMake a donation to BritishBlades
Powered by vBulletin Version 3.6.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
All images on this site are copyright www.britishblades.com. Images must not be reproduced without the express permission of the owner.
We will never share, rent or sell any member's name, email or contact information.
One of the largest message boards on the web !
