Thread Tools | Search this Thread | Rate Thread | Display Modes |
Re: Tutorial for a scandi sheath
I start of by folding a piece of paper, and mark som points to make the measument of the knife. As shown on the pic.
Trond Navigare tristesse est ;-) |
Then i cut a strip of the leather that i am going to make the sheath from. I messure at the same spots as i have selected when i marked the paper. I put the strip around the point that i want to messure, messure the lengtht of the stip, and divide it by two, and adds 3 mm. (for shrinking) I put the mark on the paper. and repeat this for all the points on the paper.
Put the leather in warm (40 degrees centigrade) water, the leather is put with the smooth side down in the water, when there is no longer comming bubles from the hide, put the leather in a plastic bag for 2 hours.
I then unfold the paper, and put it on top of the whet leather and cut with a 20 degrees angle along the sides of the paper. ![]()
Mark a line along the side of the leather, then use a markin wheel to mark where you want to stick the sawing holes.
Stick the holes, the holes should come out in the midle of the raw hide, or if you are not using raw hide, the holes shoul come out a litle lower than in the midle of the cut.
. When all th holes are finished, i make the leather a litle thinner against the tip of the sheath. and start stiching with one needle in each end of the thread.
I paint the belt strap, in the collour that i want it, in this case black. (spirit based colour)
Trond Navigare tristesse est ;-) Last edited by Trond : 06-10-04 at 11:29 AM. |
Here i am marking a decor line in the belt strap using a the end of a Tandy plastic "bone folder"
Trond Navigare tristesse est ;-) Last edited by Trond : 06-10-04 at 11:28 AM. |
Cut 6 holes two and two with apr. 8 mm between downwards.
Cut between the holes, and put the end of the beltstrap in ![]()
| Second using ZDPs easy Scandi tutorial. | ggfh666 | Scandinavian Blades... | 8 | 02-10-04 08:59 PM |
| Easy Scandi Tutorial | ZDP-189 | Tutorials Archive... | 38 | 13-09-04 12:17 PM |
| Scandi sheath pattern | ZDP-189 | Sheaths & Leatherwork... | 8 | 08-03-04 02:12 PM |
| Tutorial for a sheath for the Felleskap | Trond | Members Projects... | 4 | 30-01-04 01:19 PM |
